#1 Posted : Monday, 20 November 2006 8:10:19 AM(UTC)
Can anyone tell me if a VS ute diff is the same as a VS wagon/sedan diff?
#2 Posted : Monday, 20 November 2006 5:18:27 PM(UTC)
Sedans have different shock mounts to the ute/wagon, and cannot be swapped unless you cut them off & weld the correct mounts on (you can try forcing the shocks on, but torque twist will break the bottom eye off them).
The ute diff is similar to the wag
#3 Posted : Tuesday, 30 January 2007 7:01:35 AM(UTC)
PUGS, mate, i have no idea, but i'm in the same situation. I have a VS II ute with a screwed up diff (non LSD), and i just bought a VR Commodore sedan with an excellent non LSD diff, and was going to switch them over... What did you do? did it work?? plea
