just wondering what the diffences are between a 4cyl lj and a 6 cyl. obviously the nose cone is different but what else? thanks for your help
I had an LC 4 cyl and to be honest couldn't bother. Apparently the front end is shorter meaning you can't fit a 6 cyl in. Also the running gear is Opel stuff.
Not sure if this applies to LJ but did to LC.
WANTED: HQ/J/X/Z van in W.A., any |
WANTED: GTS rims, seats and mirrors to suit HJ. |
i have heard ppl of replacing 4cly with a 202.
rear 1/2 is all the same. Front clip and X-member needs to be changed for a 6cyl install. 4cyl LJ's are an excellent source of doors and 1/4's for GTR's & XU1's.
_______________________________________________________ If we all had the same (good) tas |
