tanart Offline
#1 Posted : Tuesday, 19 December 2006 9:50:38 PM(UTC)
tanart
Could you order the HK 327 with air conditioning? I'm the 4th owner of a HK 327 and the 3nd owner said it had air con at some stage. He did go on to explain that it had no tacho mounted on the console because of the air con unit. I also noticed on the front support that there are two holes with rubber grommets, where the hoses for the condensor poked through. How would you find out if it was dealer fitted or factory?
#2 Posted : Tuesday, 19 December 2006 11:04:13 PM(UTC)
GM-H did not allow air conditioning to be fitted to a GTS 327. A factory unit could be fitted if the dealer ordered all the original parts.
the signes on the car wold be:
Direct acting brake booster with either master cylinder with brake line coming
