Does anyone know where I can buy a radiator that will fit into the frontend of WB statesman and still keep a SB cool in the tropics? Andy
try the aussie desert range they will have what you want there number is 03 9470 4449 alumimium street and strip 4 most worked motors 750$ give them a call there website is www.aussiedesertcooler.com.aucheers damo Edited by user Tuesday, 2 January 2007 10:11:25 AM(UTC)
| Reason: Not specified
Thanks for that will call them tomorrow
What you will want is a WB 6 cyl 4 row radiator, with the outlet and inlet of the appropriate size to suit a SBC. As Damien says Aussie desert cooler will sell you one of these. You will also need a radiator shroud. A WB 6cyl one should suit the Chev with |
