#1 Posted : Friday, 2 February 2007 2:06:42 AM(UTC)
is there an easy way to remove and replace the brake booster on a hq to wb ? cheers
Munromad2004 Offline
#2 Posted : Friday, 2 February 2007 6:10:28 AM(UTC)
Munromad2004
It is held on by 4 nuts which are accessible from up under the dash.
There is also a pin that connects the brake pedal to the input rod on the rear of the booster.
The master cylinder is attached to the front of it by 2 bolts.
If you do not wish
