#1 Posted : Tuesday, 6 February 2007 7:57:51 AM(UTC)
Any suggestions?
when I turn off the car when Its hot, the water comes out of the radiator overflow. what could be the prob?
trubluhq Offline
#2 Posted : Tuesday, 6 February 2007 8:15:48 AM(UTC)
trubluhq
This is normal for a pre-overflow bottle car. My HQ is the same.
Once u turn the engine off the motor gets hotter, right ? The cap is prob rated at 90degs, so before it blows, it releases pressure. Do not change it!!!!!
You could do what I did...I
#3 Posted : Tuesday, 6 February 2007 9:00:04 AM(UTC)
On a pre coolant recovery bottle equiped car, the coolant level should be maintained approximately 25 mm below the bottom of the radiator cap. This allows for expansion of the water/coolant and SHOULD mean you don't get any overflow/loss of coolant.
Wi
