witcheshollow racing team Offline
#1 Posted : Friday, 16 February 2007 9:32:20 PM(UTC)
Ok need a bit of help here as the old grey matter fadding a bit, my daughters boyfriend has a WB ute that he wants to put a HZ prem front end on. I know the WB guards are different but I have what I thought where a set of HZ guards but the bolt pattern does not line up to the front panel. So two question 1st is there a differance between guards from a standard front end to a prem front end? and second is there a differance between HQ and HZ bolt patterns? Thanks for your help as its been years since I played with an old holden.
When the green flag drops the bulls@#t stops!!
"Such is life"
#2 Posted : Saturday, 17 February 2007 2:59:07 AM(UTC)
All nose cones for HJ to HZ use interchangeable guards EXCEPT HJ to HZ 1-tonners which run a HQ style front and guards (except HJ-HZ Ambulance 1-tonners which have HJ-HZ Premier fronts and hence use normal HJ-HZ guards).
HQ (including HJ-HZ non-ambulan
