red Offline
#1 Posted : Tuesday, 1 May 2007 6:08:04 AM(UTC)
red
Hi, ive just bought a xb gs ute. The drivers window regulator is stuffed, are the regulators the same as sedans?? Also the fuel gauge doesnt work found sender is faulty, are these the same senders in all xbs?? Thanks
Paul351xb Offline
#2 Posted : Tuesday, 1 May 2007 3:00:50 PM(UTC)
Paul351xb
Hi red, regulator is the same as the ute and panelvan. Sedan is different. Sender is also different to sedan. Utes. panel vans and I think wagons share the same sender.
Repair kits are available for the sender units. Where the fuel line exits the tank
This page was generated in 0.022 seconds.
