mzap01 Offline
#1 Posted : Thursday, 31 May 2007 11:13:09 PM(UTC)
mzap01
recently put high octane unleaded in blue 253(accidently)now motor running about 10 celcius cooler(80)is this healthy?is this usual?car is still running well.
mzap01
jabba Offline
#2 Posted : Friday, 1 June 2007 11:04:24 PM(UTC)
jabba
Different brands of fuel and different octanes often have different additives which make the engine run better / worse.
The octane itself doesn't make more or less power, it (in theory) just indicates how resistant the fuel is to detonation.
_______
Mr Void Offline
#3 Posted : Saturday, 2 June 2007 12:12:15 AM(UTC)
Mr Void
AFAIK the higher the octane rating the slower the fuel is to burn, thus it's resistance to predetonation.. if it's burning slower then you'd presume it's also going to cause less heat buildup in the motor itself.
___________________
Why are you readin
___________________
