hi have a standard v6 vp sedan (irs) wanted to fit the larger type fuel tank, will i have to change the fuel gauge in the dash as well? thanks
Hi petaus.
No you won't need to change the dash gauge, but if you have a trip computer type dash (Berlina, Calais etc) there is a switch on the back that has to be flicked from 60 litres to 80 litres.
Dr Terry. |
thanks for that terry, thats been the only thing stoping me doing it, is the pump the same v6 to v8 i.e pressure ,volume?
