#1 Posted : Wednesday, 13 June 2007 8:51:06 PM(UTC)
Hi all
I have a VR berlina v6, bought it from an auction and have done a few things to it, and now the ABS light comes on when i drive it, im not sure if it came on before i did work on it or not, what i have done to the brakes is change the front pads, bleed the brakes and i change the diff and when i did that i damaged one of the abs sensors so i replaced it with a vt abs sensor. so i was sondering if maybe the vt sensor was different to vr also could bleeding the brakes make this happen, does anyone know of any other common problems with the abs system on these cars, i had a mate who had the same thing happening to his vr. Anyway any help would be great, thanks for your time. Daniel
#2 Posted : Thursday, 14 June 2007 8:20:19 PM(UTC)
Dr Terry Online
#3 Posted : Thursday, 14 June 2007 9:22:46 PM(UTC)
Hi Daniel.
The ABS light has nothing to do with the hydraulic side of things, so you won't have caused any dramas by bleeding the system.
The are no common problems with VR/VS ABS, the only ones I've seen are problems with the wiring connectors at t
