Jvanner Offline
#1 Posted : Saturday, 7 July 2007 7:33:33 PM(UTC)
Jvanner
Driving my panel van. its a 308 M21 and 10 bolt. im getting a vibration from around the gear box area. i got the tailshaft balanced with new unis. still didnt fix all the problems. but i had to do the clutch and when i pulled out the box. the brass bush in the back of the crank which holds the box input shaft just fell out. and its alittle loose in the hole. any help in this would be great. thanks......... Jamie
hz dude Offline
#2 Posted : Saturday, 7 July 2007 9:50:29 PM(UTC)
hz dude
does it vibrate when ur drivingand
then put the clutch in ?
does it vibrate in every gear ?
was the input sharft sloppy
or damaged and whats the rear
sharft like lots of play ?
did you put a new bush in
the crank ? could be a few things
good luc
HarryO Offline
#3 Posted : Sunday, 8 July 2007 12:42:36 AM(UTC)
HarryO
Ain't it fun?? Mine turned out to be a loose (crucial) nut on the front end... but in my travels trying to work out what was wrong, I bookmarked these pages....
http://oldholden.com/?q=node/18806
http://oldholden.com/?q=node/8990
http://oldholden
#4 Posted : Sunday, 8 July 2007 2:28:36 AM(UTC)
Gday, was thevibration there be four u did the clucth? i would have a look at bell housing bolts r they all done up? ck rear mount on gear box n ck engine mounts that there not lose or broken hope this helps
#5 Posted : Sunday, 8 July 2007 2:29:46 AM(UTC)
Jvanner Offline
#6 Posted : Monday, 9 July 2007 8:45:04 AM(UTC)
Jvanner
all the bolts in area are tight. there has always been a vibration there. its like when you driving down the freeway and you run along the fog line and it vibrates. its like that. all the time. under load. its alittle worse when i back off the throttle an
#7 Posted : Monday, 9 July 2007 10:10:37 PM(UTC)
Are you sure it's not a bent rear wheel or axle?
#8 Posted : Tuesday, 10 July 2007 6:34:30 AM(UTC)
Jvanner.I would fix the spigot problem before doing anything else it can add to clutch plate alignment/balance problems.
ED57FE Offline
#9 Posted : Friday, 20 July 2007 9:02:42 PM(UTC)
ED57FE
Hello,
It sounds like you may have a misaligned driveshaft.
check the angle of the gearbox, drivshaft and pinion angle.
a heap of factors can also contribute.
broken gearbox mount, engine mount etc.
I just re-set my driveline and with the veh
