I need to replace my ABS module and have been offered one.
The numbers on it are 92080879 and 0 265 219 458. The Bosch numbers are 872520 0 273 004 389.
Can anyone tell me if this is suitable for my 99 VT V6 Calais with traction control.
Thanks: 1 times Was thanked: 242 time(s) in 216 post(s)
Hi leroybrown.
No, that unit is from a VTII/VX Gen 3 V8. Also from the numbers you have there, it sounds like more than just a module. It sounds like you have the entire ABS pump unit. The electronic module is the black bit on the side, its held on by |
Hi leroybrown.
No, that unit is from a VTII/VX Gen 3 V8. Also from the numbers you have there, it sounds like more than just a module. It sounds like you have the entire ABS pump unit. The electronic module is the black bit on the side, it's held on by |
