keithholden Offline
#1 Posted : Tuesday, 11 September 2007 3:27:28 AM(UTC)
keithholden
Hi My flex fan is 9mm from touching the bonnet is that enough room or will I need to trim the blades??
Im not sure if the motor moves up and down
#2 Posted : Tuesday, 11 September 2007 4:10:41 AM(UTC)
the motor may move a little , but the blades may alter also under driving conditions, try and see what happens.
keithholden Offline
#3 Posted : Tuesday, 11 September 2007 5:06:52 AM(UTC)
keithholden
Lol oh yeah true the fan kind of straightens up when you rev the engine.
Its weird cause the fan doesnt go to the bottom of the radiator but it goes above the top tank.
Maybe when I bent my cross member to get enough room to put my floor shifter in I
