#1 Posted : Wednesday, 26 September 2007 9:53:09 AM(UTC)
Hi, I am after a C4 transmission oil cooler pipe. The one that takes the fluid from the front of the transmission to the bottom of the radiator. To Suit a 302 V8 XC or ZH Fairlane. It doesn't matter if the fitting on the transmission end is stuffed because I am cutting it off to put a gauge in, but the radiator end must be good. Thanks.
#2 Posted : Saturday, 6 October 2007 9:25:05 AM(UTC)
Im still looking if anyone's got one. Anyone?
Paul351xb Offline
#3 Posted : Saturday, 6 October 2007 3:07:25 PM(UTC)
Paul351xb
Wouldn't the pipe out of an XD or XE 6 cyl fit? Pretty much the same gear box and radiatior plumbing. If you're going to the trouble you might as well invest in a seperate tranny cooler. They go pretty cheap on e bay.
#4 Posted : Monday, 8 October 2007 8:08:01 AM(UTC)
I just upgraded my cooler to a bigger one, actually my old one is on E BAY. I am using the stock cooler still as well. I might spend the extra cash and go for braided lines although things look a bit tight for them between the extractors and the pitman ar
Paul351xb Offline
#5 Posted : Tuesday, 9 October 2007 1:26:19 AM(UTC)
Paul351xb
XD to XF all used cross flow radiators, same as the 302 V8s from XA to XC. I'm not sure how much difference there is in the plumbing with the borgy and the C4 though.
This page was generated in 0.097 seconds.
