gday everyone can any one tell me the difference between these 2 slave cylinders or what they are off by part# holden 7429743 p252 & holden 7409134 they both seem to have same bore size as i can put same piston in either Edited by user Thursday, 25 October 2007 5:16:15 AM(UTC)
| Reason: Not specified
Couldnt find either in HK-HQ, LC-LH.
Couldn't find either in HK-HQ, LC-LH.
i just typed it into my database and couldnt find anything either.
Rare Spares Perth (REX SPARES) Representative. If you have an enquiry, feel free to message me. T
Hi Guys.
These are not part numbers, they are casting numbers. The 7409134 is the body of the clutch slave cylinder used for FE/FC/FB/EK series. The 7429743 is the body of the clutch slave cylinder used on HR Opel 4-speed gearboxes. These 2 are very si |
cheers fellas just a few more questions if the 743 is for an opel box why does it have a spring hook on both sides of the cylinder did they interchange with other set ups is this what you mean dr terry with afaik can interchange do you know the cast numbe Edited by user Saturday, 20 October 2007 8:46:36 AM(UTC)
afaik = as far as i know.
__________________________________________ Keep the shiny side up, and the greasy side down. |
quote: Originally posted by hazzard county
cheers fellas just a few more questions if the 743 is for an opel box why does it h |
I cant find a genuine slave here.
I can't find a genuine slave here.
i rang a brake reconditioning joint today which does alot of restoration work on vintage & muscle cars & they checked there data base & come up with a pbr number for v8 & a gm number for the 6 cylinder as dr terry suggested the correct cylinder sizes but
