Hi, It looks as if my 10 stacker has seen better days. Does anyone know if there is a radio and or CD player after market that I can replace my original one with that will still work with the Caprice buttons in the roof for the passengers too use? If not I suppose Ill have to get the stacker repaired.
Cheers Frenzo
Hi Frenzo,
What problems are you having with the 10 disc stacker? A common problem is Error 99 on the LCD display of the stereo when trying to play a cd. I (and a few others that I know of) have had this problem and all it was was a faulty connection b
The roof buttons share the same input wire as the steering wheel ones. I modded the headlining in my VS Calais with VS caprice buttons (and the other gadgets) and a VQ clock. When I wired it up, the roof buttons simply ran to the brown signal wire in th |
Hey Frenzo, I stumbled across this when I was googling something, and figured it may help you. Have a read of this page: http://www.caraudioaustr...on/index.php/t44151.htmlCheers, Mick ________________________________ |
