wbtonner Offline
#1 Posted : Wednesday, 31 October 2007 8:01:02 PM(UTC)
wbtonner
I am installing WB Caprice electric mirrors onto my WB ute using a mirror switch from a VL commadore. I am not sure but I think this is the same switch from a WB caprice??? The switch has a six blade conector on the rear. I am also not sure how to wire this switch up to the mirrors. The mirrors have three wires each (black, brown, white) which drive the motors. Can anyone help with a wiring diagram or with instructions on how to connect the mirrors to the swich and to power.
Edited by user Wednesday, 31 October 2007 8:25:06 PM(UTC)  | Reason: Not specified
#2 Posted : Wednesday, 31 October 2007 9:26:31 PM(UTC)
You need a pair of 5 pin changeover relays as well.
WB ran the same setup for the mirrors as VK & VL commoodore/calais. Even down to the wire colours & plugs.
Might be easier to grab the mirror harness from a VK or VL commoodore - the relays in que
wbtonner Offline
#3 Posted : Thursday, 1 November 2007 3:43:14 AM(UTC)
wbtonner
Thanx for the quick reply Mick. Yes I am open to suggestions. I have a GTS dash and was going to mount the switch on the console between the seats, so any combination that works will be good. I would be grateful if you could get me a copy of the wiring di
