#1 Posted : Thursday, 1 November 2007 5:01:08 AM(UTC)
Excusing my ignorance, can somebody tell me how easy is it to upgrade a 4 cylinder engine in an LH torana to a 6 or 8 cyl? Do the engine mounts align? Or what modifications are required?
Thank you
adam PERTH Offline
#2 Posted : Thursday, 1 November 2007 5:08:48 AM(UTC)
adam PERTH
David.
Try the search function on LHS of page.
type in
LX LH torana conversion.
this was discussed only as recently as a month ago.
goodluck:-)
by all means, if you have further questions, post them asap.
A1 Bogan.
#3 Posted : Thursday, 1 November 2007 4:11:50 PM(UTC)
Was thanked: 559 time(s) in 534 post(s)
You'll need to change the engine crossmember. Sounds hard but it's not that difficult - 6 x bolts, steering and brake lines. Easy whilst the engine is out. Best way to go is to get a complete UC Torana 6cyl or Starfire 4 crossmember and fit it. Will total
#4 Posted : Thursday, 1 November 2007 4:11:50 PM(UTC)
Youll need to change the engine crossmember. Sounds hard but its not that difficult - 6 x bolts, steering and brake lines. Easy whilst the engine is out. Best way to go is to get a complete UC Torana 6cyl or Starfire 4 crossmember and fit it. Will totally
