stevo280472 Offline
#1 Posted : Monday, 5 November 2007 4:39:22 AM(UTC)
stevo280472
Hi, are the pads easy to change on a HG Brougham? I only have limited mechanical experience but have done it on other makes. Any tricks?
Go the Dragons!
81837 Offline
#2 Posted : Monday, 5 November 2007 4:57:04 AM(UTC)
81837
Very simple Steve, the pins are retained by spring clips (R-clips), pull the R-clips, slip the pins out and the pads will come out the top, I used a pair of long nose pliers to grip them. You then need to push the pistons back into the calipers to make ro
This page was generated in 0.015 seconds.
