#1 Posted : Friday, 7 September 2007 6:38:40 AM(UTC)
Guys
Is there an easier way to fit a quality (and large) auto transmission cooler to a VZ, apart from making all the mounting hardware yourself?
I want to fit one to the Cross 8 but the genuine one is over $400 (with brackets). Good quality aftermarket units like B&M etc are much cheaper but you have to stuff around with custom bracketry. I dont want to drill holes - just use factory holes (meaning complicated bracketry), plus I won't use those stupid zip tie setups.
Has anyone successfully mounted a cooler under the tray/wellback with an electric fan? I thought of sticking one up under there in series with the standard in-radiator cooler and maybe directing a bit of ducting over to it so it gets some airflow.
This page was generated in 0.015 seconds.
