witcheshollow racing team Offline
#1 Posted : Tuesday, 25 December 2007 4:59:34 AM(UTC)
I put a new pick up pipe into the tank and soldered around it then added a little expoxy to make sure it was sealed but it seams to still be weeping a little. Anything else I could use to prevent the weeping ?
"Such is life"
"Such is life"
#2 Posted : Tuesday, 25 December 2007 5:04:53 AM(UTC)
Doesnt the company POR15 do a tank sealer? i think you puy it in and stand there and slowly turn the tank over to give it a full seal.
#3 Posted : Tuesday, 25 December 2007 5:38:14 AM(UTC)
Dam that will mean I have to pull the tank out!! Thanks I will look into it.
"Such is life"
"Such is life"
jabba Offline
#4 Posted : Tuesday, 25 December 2007 6:31:10 AM(UTC)
jabba
I put a bunch of the "knead it" product in the hollow where the pickup goes through, then painted over it. Not a problem since.
