Hey,
can someone tell me if the HD X2 was an optioned up prem or special ... maybe both... and to show its an X2 is there any subtle differences other than badges, carbs anddash
cheers Alan
Drive carefully! Remember, it's not only a car that can be recalled by it's maker |
Hi Alan
An HD X2 wasn't a separate 'model', as such.
The X2 was an engine option package that you could order on any model HD (including utes & panel vans).
Most X2s I've seen have been Special or Premier sedans, although back in their day an HD |
Hi Alan
An HD X2 wasnt a separate model, as such.
Most X2s Ive seen have been Special or Premier sedans, although back in their day an HD X2 P |
Hi Dr Terry
was option X2 listed on the ID tags?
Drive carefully! Remember, its not only a car that can be recalled by its maker |
Hi Dr Terry
The ID tags didnt reflect the X2 option, it was as Dr Terry said in his post, they were the distinguishing factors. The only thing Ill add is the engine number on the HD X2 was prefixed 179X..... to seperate it from the run of the mill 179.
I think ut |
202 and three on the tree, can't get more Aussie than that!! |
The ID tags didn't reflect the X2 option, it was as Dr Terry said in his post, they were the distinguishing factors. The only thing I'll add is the engine number on the HD X2 was prefixed 179X..... to seperate it from the run of the mill 179.
I think |
Hi Peter
Quote:-
"I think utes and panelvans with the X2 option (a very rare item indeed) had the badge in the centre of the tailgate AFAIK."
AFAIK all HDs had their engine badges on the right-hand side of the lower tailgate & all HR had theirs o |
Did the HD 179 x2 have a lighter colour red motor? with gold air filter and gold breather. eng prefix 179x. And the HR 186 x2 have the same red as the rest, with silver air filter and eng prefix 186 x2 and HR 186 s with 186 s prefix. as with all 186 s.
A friend back in the early 80s bought a white HR ute in Karratha, 3 speed manual, X2 engine, front discs, dead stock apart from the period dragway(or similar style) mags. The body was knackered with big rust hols in the floorpan, but even so ... from mem
quote: Originally posted by RICK
Did the HD 179 x2 have a lighter colour red motor? with gold air filter and gold breather. |
The HT had the 186S cam in all 186 engines, it was the HG auto that had the old 186 cam fitted, but advertised power output still remained at 130BHP. The trimatic 186S got the same treatment.
Warren
The HK-T-G 186S the same colour motor as std norm 186 ? Its weard that 186S has a K prefix. in the HR X2 S and HK S. The std 186 HT and the HG manual have the s cams, do they have the S valve springs. The auto HG 186 s got, THE STD CAM ?
quote: Originally posted by ROSENBERG
The HK-T-G 186S the same colour motor as std norm 186 ? Its weard that 186S has a K pr |
