As I said before Im not a real diff man but was wondering what the differance is between a 6 and 8 cylinder diff in a WB ute? (excluding ratio differances)
"Such is life" |
"Such is life" |
small 10 bolt and large 10 bolt..small runs same crown wheel and pinnion as a banjo and large runs same crown wheel and pinnion as a 1 tonner lets say.diff yokes are the same for 6 and 8 in utes/vans but 1 tonner is larger.small 10 bolt is not as strong a |
So is it possible to change the center from a V8 sedan into a 6 cylinder housing then?
This then moves to an added question is there a differance in tail shafts?
"Such is life" |
"Such is life" |
no its not as the 6 is smaller...
going to church makes you no more a christian than standing in a garage makes you a car... |
6cyl WB diff is the same as 4,6 and 253 Commodores and UC Torana. WB 6cyl diff is rarer than the V8 one as the V8 one is the same as HQ-HZ V8 and HQ-HZ tonner (apart from HZ and WB having integral sway bar mounts), whereas HQ-HZ 6cyl ute/van have a banjo. |
