81837 Offline
#1 Posted : Saturday, 19 January 2008 11:37:59 PM(UTC)
81837
My saginaw has a 2.54:1 first gear ratio (apparently), what is the other ratio, why the difference?
#2 Posted : Sunday, 20 January 2008 12:26:58 AM(UTC)
Saginaw 4-speed 1st 2nd 3rd 4th
No lines (grooves) 2.84 2.01 1.35 1.00
1 Line (groove ) 2.54 1.80 1.44 1.00
2 Lines (grooves) 3.11 2.20 1.47 1.00
3 Lines (grooves) 3.50 2.47 1.65 1.00
Others found but not with complete specs:
#3 Posted : Sunday, 20 January 2008 12:36:51 AM(UTC)
Yours is an M21. There was an M22 Saginaw with 2.85 1st which was standard fitment to 6cyl HK utes/vans if you ordered a 4spd. The M22 was also used on HT 186S if ordered with heavy duty 4spd.
If
#4 Posted : Sunday, 20 January 2008 12:42:37 AM(UTC)
as for why... you probably understand the difference between a low ratio diff (say a 4.11) and a high ratio (say 2.78). To understand the gearbox ratio difference all you need to do is multiply the ratio by your rear gear ratio to get your final drive rat
