boom Offline
#1 Posted : Friday, 25 January 2008 10:21:10 PM(UTC)
boom
what are the original cam specs for the 186? just wanted to know because i was told they're great in forced induction 202s.
#2 Posted : Friday, 25 January 2008 10:27:00 PM(UTC)
Was thanked: 611 time(s) in 578 post(s)
An original one won't actually fit in a 202 - the rod bolts hit it. There are a few different cams depending upon model, engine spec (eg 186S, 186X) and transmission.
If we all had the same (good
#3 Posted : Friday, 25 January 2008 10:27:00 PM(UTC)
An original one wont actually fit in a 202 - the rod bolts hit it. There are a few different cams depending upon model, engine spec (eg 186S, 186X) and transmission.
If we all had the same (good)
boom Offline
#4 Posted : Friday, 25 January 2008 10:52:34 PM(UTC)
boom
riighht. so there's no way to fit a 186 cam in the 202 hey? well looks like i've been bull****ted. It's a 186P out of an HG
boom Offline
#5 Posted : Friday, 25 January 2008 10:52:34 PM(UTC)
boom
riighht. so theres no way to fit a 186 cam in the 202 hey? well looks like ive been bull****ted. Its a 186P out of an HG
#6 Posted : Saturday, 26 January 2008 2:47:30 AM(UTC)
An aftermarket 186 cam will fit a 202. Or you could grind out the rod reliefs. But an original one won't, and you wouldn't bother when you could get a new one made with the same profile if that is what you wanted.
______________________________________
#7 Posted : Saturday, 26 January 2008 2:47:30 AM(UTC)
An aftermarket 186 cam will fit a 202. Or you could grind out the rod reliefs. But an original one wont, and you wouldnt bother when you could get a new one made with the same profile if that is what you wanted.
________________________________________
