how do i get the Rear Seat out of the HG Wagon? can anyone help me out I'm slightly stuck cheers
i don't know whether it's the same, but in the commodores you pull the base out by hand, from between the top half and the base, and then it's pretty clear after that. may be different on a wagon.
If nissan motorsport is nismo, the
i dont know whether its the same, but in the commodores you pull the base out by hand, from between the top half and the base, and then its pretty clear after that. may be different on a wagon.
If nissan motorsport is nismo, then d
thanks for that mate it worked a treat. appreciate your help.
no worries.
no worries.
