hi i was unable to find my code for my radio. does anyone know how to get them.
Hi steve.
What model car do you have, there are many different procedures.
Dr Terry |
thanks dr terry . vt aclaim its a audiosonic cassete no cd player . hope u can help
Hi steve.
A VT Acclaim was factory-fitted with a Eurovox audio unit. If you have something aftermarket only god will know how get the code.
If it does have the factory Eurovox unit, its PIN code is stored in the cars BCM & can be extracted used a pr |
Hi steve.
If it does have the factory Eurovox unit, its PIN code is stored in the car's BCM & can be extracted used a p |
hi dr terry thanks mate .. sorry its a eurovox not auoiosonic .. im in perth.. thanks
Had the same problem with an EA, don't know about Holden but Ford only keep those records for ten years so the go was (in my case) pull the radio out and somewhere on it will be a sticker or plate with a serial number and the manufacturer/importer name ri
Had the same problem with an EA, dont know about Holden but Ford only keep those records for ten years so the go was (in my case) pull the radio out and somewhere on it will be a sticker or plate with a serial number and the manufacturer/importer name rin
