hi guys I don't have a parts manual for the WB, so can anyone verify if the following options were available on the WB Kingswood ute? - triple gauge (standard cluster with an oil pressure gauge alongside the temp gauge). Was optional on the HZ. - GTS rims - alloy SLE rims (optional on de Ville) - factory electric aerial (as per the HZ) - AM/FM pushbutton radio - Statesman SLE (HZ) style coloured coded steering wheel cheers franklin
N66 GTS rims were finished early 1979 and replaced by N67 rims (known as HZ SL/E) which were optional on WB utes from memory. Not sure about the rest.
_______________________________________________________ If we all had the same (good) taste, who wou |
Were the N67 rims ever done in a 15"? or was it commodore only.?
A1 Bogan. |
thanks Byron, thats a good start, I guess a parts manual will answer the rest! Adam - the 15" rims were Commodore only up until early VH, and the 13" style were found on the Gemini SLEs (TD and later) and Sunbird SLEs and from memory, also listed as opti
cheers for that, just wanted to make sure. also WB kingswood came put optional GTS dash and also triple dash
Rhys (Hi Rhys) has a triple dash in his WB kingswood.
A1 Bogan. |
Hi Guys, Yes I do have a yellow needle triple gauge in my ute. Its the first one I've ever seen in a WB, and it surely must have been an option.
Franklin I don't think the electric aerial was available in the WB commercials, I don't think they would
Hi Guys, Yes I do have a yellow needle triple gauge in my ute. Its the first one Ive ever seen in a WB, and it surely must have been an option.
Franklin I dont think the electric aerial was available in the WB commercials, I dont think they would hav
WB's had a lot of unusual options due to the fact that dealers and the factory were quite accomadating when it came to options. They had parts left over that needed to get used up.
Never late in a V8 |
WBs had a lot of unusual options due to the fact that dealers and the factory were quite accomadating when it came to options. They had parts left over that needed to get used up.
I actually just purchased another one on the weekend 260,000 Km Factory L36, M20, 2 seater, factory fitted GTS dash in Bamboo (beige) it has all Beige interior
A1 Bogan. |
from wb catalogue oct83 m39027 text section -Radio package AWA push button AM/FM 92003084 other is AM only, 4 cassette players are listed for all models -Only 2 antenna listed 1 is a lockdown type and the other is spring base, electric is for statesman |
"Planet earth is the asylum to which the rest of the universe sends it's lunatics" Voltaire |
hi guys thanks for all the replies, much appreciated. I checked out my WB commercial brochure and the electric antenna was a dealer fitted accessory, as I'm sure were many other things.
AND
according to the WB parts manual (managed to have a peek
hi guys thanks for all the replies, much appreciated. I checked out my WB commercial brochure and the electric antenna was a dealer fitted accessory, as Im sure were many other things.
AND
according to the WB parts manual (managed to have a peek a
No but I now have a full colour photo of a Tail-Tent. Looks just like a Hatch-hutch!
Factory tinted glass also?
A1 Bogan. |
