Slamd Hk Offline
#1 Posted : Tuesday, 19 February 2008 8:21:42 PM(UTC)
Slamd Hk
Hi All,
I have just fitted some new upper balljoints on the prem on the weekend & the new ones don't have split pins (just them nylon looking nuts) Do i tighten them so they are completely tight ?
Slamd
MLD
MLD
tanart Offline
#2 Posted : Tuesday, 19 February 2008 8:42:18 PM(UTC)
tanart
I just finished rebuilding my HK front end and i too had the nylon nuts. Just completely tighten them (dont over tighten them) and youll be okay. Or you can use your original nuts with the split pin.
tanart Offline
#3 Posted : Tuesday, 19 February 2008 8:42:18 PM(UTC)
tanart
I just finished rebuilding my HK front end and i too had the nylon nuts. Just completely tighten them (dont over tighten them) and you'll be okay. Or you can use your original nuts with the split pin.
#4 Posted : Tuesday, 19 February 2008 9:10:17 PM(UTC)
Thanks , I have only tightened them up by hand , i don't beleive they will be over tightend.
Slamd
#5 Posted : Tuesday, 19 February 2008 9:10:17 PM(UTC)
Thanks , I have only tightened them up by hand , i dont beleive they will be over tightend.
Slamd
