torana186 Offline
#1 Posted : Sunday, 24 February 2008 10:24:43 AM(UTC)
torana186
hi can anyone help me im wanting to convert my 2 door TA torana to the LJ front sheet metal. im wanting to know how hard it will be to do? whats the difference in wheel base? what is required for the conversion in the way of sub frame change? do i need to fabricate new inner guards? plus any other ideas/hints/tips that would be useful
thanks
#2 Posted : Monday, 25 February 2008 12:00:00 AM(UTC)
very big project
chassis rails on 4cyl are thinner, so too small to mount front suspention and diff, mounting brackets/bolts different need to replace with 6cyl or heavily modify
firewall is diff as well but 6cyl panels will fit
you will need
chassis
#3 Posted : Monday, 25 February 2008 12:08:12 AM(UTC)
previous was for full conversion 4cyl to 6cyl
if you only want to replace front panels
need to mod and extend chassis rails and use full 6cyl front clip, inner/outer guards etc
