im trying to get the crank out of my 202. have got everything out accept for the timing case does the harmonic balancer come off in 2 parts ive used a gear puller to get it off but i cant get it behind the small part? how do i do this is there a knack? I'm stuck and its annoying the hell out of me koz its the only thing left on the block... please help. cheers
screw in gear puller. had that same problem
i have one of those but i cant get it in behind. any suggestions?
doesnt go in behind it has 3 bolts you screw into the pulley hub and a centre one you tighten to pull the hub off.
doesn't go in behind it has 3 bolts you screw into the pulley hub and a centre one you tighten to pull the hub off.
