#1 Posted : Friday, 29 February 2008 8:24:16 AM(UTC)
Hi all
I was wondering if anyone could advise on the following. I have just bought an Hz Kingswood 3.3 with standard banjo diff set up. Car has done about 300,000 kms. Motor and transmission have been fully overhauled but diff has never been touched and seems to work ok with no real noise.
Question is should the oil be changed. The factory service manual says that it is not necessary but the factory probably wasn't banking on the car having a service life of over 30 years. Then again if it ain't broke....
Thanks for any advice
basketcasebear Offline
#2 Posted : Friday, 29 February 2008 9:58:42 AM(UTC)
basketcasebear
dont know charles?? but i would like to know the best oil to put ina borg warner diff???? cause i just put a new gasket on mine today...
bcb
ptpro
some men see things as they are, and ask "why"
I dream of things that never were, and say, "
DOH!!!
crowe Offline
#3 Posted : Sunday, 2 March 2008 11:29:35 PM(UTC)
crowe
yes change it,
keithholden Offline
#4 Posted : Monday, 3 March 2008 8:32:15 AM(UTC)
keithholden
I think u use a bottle that you water hanging pots with and squeeze the bottle and then put the tube in the diff and it sucks it out. Not sure if you can get the tube deep into the diff or not.
You could then check the condition of the oil and also the
