#1 Posted : Friday, 21 March 2008 2:30:45 AM(UTC)
when fitting wb disc drum master cylinder to a hq is there anything else to change eg brake pedal or booster ? i know the pipes have to have metric sizes at the wb master and imperial to match the hq brake block and to remove the proportioning valve from under the car all the best
#2 Posted : Friday, 21 March 2008 2:48:35 AM(UTC)
Was thanked: 601 time(s) in 568 post(s)
You'll have to change both the pedal and booster. HQ-HZ all alloy PBR master cylinder is a better one anyway, so why change?
#3 Posted : Friday, 21 March 2008 2:48:35 AM(UTC)
Youll have to change both the pedal and booster. HQ-HZ all alloy PBR master cylinder is a better one anyway, so why change?
