briane Offline
#1 Posted : Wednesday, 9 April 2008 3:27:43 AM(UTC)
briane
Hi guys. Can any one give me an idea of what size jets and power valve to run in a 350 holley on a red 202 in my LC Torry? It runs a warm head, extractors and 2' system and is auto.
Thanks in advance.....Brian
adam PERTH Offline
#2 Posted : Wednesday, 9 April 2008 5:14:45 AM(UTC)
adam PERTH
59 jets and 5.5 power valve.
the clearance of the powervalve is proportional to your diff ratio / cam, it should never be touching at idle.
#3 Posted : Saturday, 12 April 2008 4:35:41 AM(UTC)
The power valve number is what vacume pressure it turns on at. So the lower the number the later it will come on as manifold pressure drops as you acclerate.
But at full throttle they all comeon no matter what.
#4 Posted : Saturday, 12 April 2008 4:42:58 AM(UTC)
There are 4 parts to the carb that need to be correct,
First the idle jets , rich lean or correct.
Next the ummm block thing ... arhh
metering block.
then the thing on the side that has a small lever attached.. ahhh.
Acclerator pump. adjustment.
Th
#5 Posted : Saturday, 12 April 2008 4:47:51 AM(UTC)
Question: Is the Holley spreadbore better than my Rochester Quadrajet?
Answer: Not at all. The Holley spreadbore carb is a poor imitation of the Rochester Quadrajet. Here's why.
The Rochester Quadrajet is a modern design, and uses some very forwar
#6 Posted : Saturday, 12 April 2008 4:47:51 AM(UTC)
Answer: Not at all. The Holley spreadbore carb is a poor imitation of the Rochester Quadrajet. Heres why.
The Rochester Quadrajet is a modern design, and uses some very forward
