2 Pages<12
#21 Posted : Wednesday, 16 April 2008 10:06:16 PM(UTC)
Its OK for a 308, but with big tyres and an LSD they do break especially with a manual - ask any Brock owner. Drive sensibly and they are alright. For performance work youd be better off with a 9" or a VN diff especially as parts are much easier to get ho
#22 Posted : Wednesday, 16 April 2008 10:06:16 PM(UTC)
It's OK for a 308, but with big tyres and an LSD they do break especially with a manual - ask any Brock owner. Drive sensibly and they are alright. For performance work you'd be better off with a 9" or a VN diff especially as parts are much easier to get
clyde60 Offline
#23 Posted : Wednesday, 16 April 2008 10:11:15 PM(UTC)
clyde60
What sort of diff does a VN have? Do they fit straight in or do they need mods? Do other model commodores run the same diff?
boom Offline
#24 Posted : Thursday, 17 April 2008 1:44:34 AM(UTC)
boom
VN has a Borg Warner 4 pinion 28 spline centre. not sure if LSD was standard though, good chance they were
In cubes we trust.
mrhqute Offline
#25 Posted : Sunday, 20 April 2008 6:31:21 AM(UTC)
mrhqute
What would the ratio be in a VN V8 LSD disc brake rear end?
Ross
clyde60 Offline
#26 Posted : Sunday, 20 April 2008 6:03:57 PM(UTC)
clyde60
When suggesting an efi motor for the conversion everyone is sugesting a motor out of a VN/VP. Isthere a reason the later model motors, say VR/VS are not as good?
#27 Posted : Sunday, 20 April 2008 6:57:26 PM(UTC)
Later engines have to have the Memcal changed to remove the body control module input. They are actually better though in one way as the speedo input to the ECU is 10 pulse per rev and dont need an adapter like the earlier which need 2 pulse per rev. The
#28 Posted : Sunday, 20 April 2008 6:57:26 PM(UTC)
Later engines have to have the Memcal changed to remove the body control module input. They are actually better though in one way as the speedo input to the ECU is 10 pulse per rev and don't need an adapter like the earlier which need 2 pulse per rev. The
2 Pages<12
