253tonner Offline
#1 Posted : Friday, 18 April 2008 5:12:37 AM(UTC)
253tonner
if anyone out there can help me i am putting electronic dissz in
in my hz v8 what wires in the igniton do i have to change to mack straight 12 volts to mack it work right just asking if anyone can
many thank allen
OLD UTE & TONNERS LIVE FOR EVER V8 NEVER DIE
old holden rule
v8 are the go who
give's sh## about
fuel
JBM Offline
#2 Posted : Friday, 18 April 2008 4:34:06 PM(UTC)
JBM
Bypass then cut the existing wire that runs from the ignition to the coil, your existing wire will have a resistor built into it to drop the voltage to suit points.
James
You only have to be i
This page was generated in 0.022 seconds.
