#1 Posted : Saturday, 19 April 2008 2:07:22 AM(UTC)
what vl commodore was fitted with rear discs only the calais or was it an option on across the range a lot i have seen have drums i read the 3. litre used a 3.45 ratio thats what i am after plus the discs oao thanks
#2 Posted : Monday, 21 April 2008 10:45:37 PM(UTC)
All V8's, turbo's and I think Calais had rear discs. They were optional on any model not standard with them.
Rear discs will fit off any Commodore at least from VB-VP (non IRS). Straight bolt on to any drum brake rear but you have to change the whee
#3 Posted : Monday, 21 April 2008 10:45:37 PM(UTC)
All V8s, turbos and I think Calais had rear discs. They were optional on any model not standard with them.
Rear discs will fit off any Commodore at least from VB-VP (non IRS). Straight bolt on to any drum brake rear but you have to change the wheel
