Will a T350 fit a powerglide crossmember with no mods???
Basically, but it has to be a V8 powerglide. HK also have spacers between the crossmember and the body but i'm not sure how this is done in HT/G ie if the extra clearance is already in the crossmember.
__________________________________________________ |
Basically, but it has to be a V8 powerglide. HK also have spacers between the crossmember and the body but im not sure how this is done in HT/G ie if the extra clearance is already in the crossmember.
___________________________________________________ |
