I have purchased a hq ute with a supra 5 speed in it. It has a cable clutch pedal, but I think it may be the wrong one. I just don't think the clutch is disengaging properly. Can anyone give me the dimensions of the correct pedal so I can check mine.
Thanks Ross
Thanks: 1 times Was thanked: 558 time(s) in 533 post(s)
Is the pedal hanging down further than the brake pedal? If it is you have a WB 6cyl pedal and need a V8 one. The other problem is the clutch fork travel is less than you really need due to the shorter input shaft of the Supra box. Have a look at the follo |
The clutch pedal is actually higher than the brake pedal. (higher as in further from the floor, not further from the firewall) See picture here <a href="http://s304.photobucket.com/albums/nn189/mrhqute/?action=view¤t=PIC_0038.jpg" target="_blan
Oops, Ill try again. Damn, how do you post a link?
Oops, I'll try again. Damn, how do you post a link?
