#1 Posted : Tuesday, 22 April 2008 5:49:32 AM(UTC)
Hi I want to lower my fx ute and wanted to see if anyone had any advice to give I only want to lower it a few inches but don't want the front end to suffer for it.
Rod32320 Offline
#2 Posted : Wednesday, 23 April 2008 2:59:09 AM(UTC)
Rod32320
You occasionally see a set of 2 inch lower front springs on ebay. The rear can be lowered with lowering blocks.
ScaryXdragHK Offline
#3 Posted : Wednesday, 23 April 2008 3:06:17 AM(UTC)
ScaryXdragHK
Lowering blocks are OK for something that will be travelling at FX Holden speeds. Getting your springs re-set is a much better (but more expensive) option. If you shop around, you should be able to get a decent rate, I was offered spring re-setting for $
#4 Posted : Wednesday, 23 April 2008 3:44:41 AM(UTC)
Thanks I was wondering If I could lower the front at all without stuffing up the camber but its good to hear a couple of inches is ok. Thanks for your help
#5 Posted : Wednesday, 23 April 2008 3:44:41 AM(UTC)
Thanks I was wondering If I could lower the front at all without stuffing up the camber but it's good to hear a couple of inches is ok. Thanks for your help
special-k Offline
#6 Posted : Wednesday, 23 April 2008 4:13:27 AM(UTC)
special-k
Mate the best thing would be to get some drop spindles from castle main rod shop thats if you are running the HR front end.The best option for the rear as scaryx said is resetting the rear springs.
Rod32320 Offline
#7 Posted : Wednesday, 23 April 2008 4:18:50 AM(UTC)
Rod32320
there's a pair of new lowered front springs on ebay now Item number: 250238954161
Rod32320 Offline
#8 Posted : Wednesday, 23 April 2008 4:18:50 AM(UTC)
Rod32320
theres a pair of new lowered front springs on ebay now Item number: 250238954161
This page was generated in 0.185 seconds.
