e bay blocks 30745849 k 09 (sept) ** , 30744738 k 09 (sept) 27 , Mine 307451** k 07 (july) 08 . How did the assign engine numbers. Bazza.
Thanks: 1 times Was thanked: 613 time(s) in 580 post(s)
30700001 - 09999 Acacia 30710000 - 39999 Pagewood 30740000 - 73999 Dandenong 30774000 - 89999 Elizabeth
yes byron, these are all melb blocks,2 sept with mine july yet mine was stamped between the others if Im right. Seems odd. Bazza.
You do find discrepencies like this when you get them together, but normally only a week or thereabouts in HK. They do start to get all over the place in HT/G though. As long as all the number stampings look the same don't worry about it. How close do the Edited by user Thursday, 15 May 2008 4:23:15 PM(UTC)
| Reason: Not specified |
You do find discrepencies like this when you get them together, but normally only a week or thereabouts in HK. They do start to get all over the place in HT/G though. As long as all the number stampings look the same dont worry about it. How close do the Edited by user Thursday, 15 May 2008 4:23:15 PM(UTC)
Where are the date codes on the side of the blocks.I know my numbers are right because I have the original owners service books. I still do plumbing work for the original owner. Thanks Bazza.
On one side of the block near the freeze plugs on the McKinnon blocks. Big wide number across a few inches from memory. It's on the rear near the casting number on Tonnawanda 327 and 350 blocks.
On one side of the block near the freeze plugs on the McKinnon blocks. Big wide number across a few inches from memory. Its on the rear near the casting number on Tonnawanda 327 and 350 blocks.
_______________________________________________________ I |
