#1 Posted : Thursday, 15 May 2008 7:30:09 AM(UTC)
e bay blocks 30745849 k 09 (sept) ** , 30744738 k 09 (sept) 27 , Mine 307451** k 07 (july) 08 . How did the assign engine numbers. Bazza.
#2 Posted : Thursday, 15 May 2008 7:39:23 AM(UTC)
30700001 - 09999 Acacia
30710000 - 39999 Pagewood
30740000 - 73999 Dandenong
30774000 - 89999 Elizabeth
#3 Posted : Thursday, 15 May 2008 7:46:51 AM(UTC)
yes byron, these are all melb blocks,2 sept with mine july yet mine was stamped between the others if Im right. Seems odd. Bazza.
#4 Posted : Thursday, 15 May 2008 4:22:33 PM(UTC)
You do find discrepencies like this when you get them together, but normally only a week or thereabouts in HK. They do start to get all over the place in HT/G though. As long as all the number stampings look the same don't worry about it. How close do the
Edited by user Thursday, 15 May 2008 4:23:15 PM(UTC)  | Reason: Not specified
#5 Posted : Thursday, 15 May 2008 4:22:33 PM(UTC)
You do find discrepencies like this when you get them together, but normally only a week or thereabouts in HK. They do start to get all over the place in HT/G though. As long as all the number stampings look the same dont worry about it. How close do the
#6 Posted : Friday, 16 May 2008 4:21:18 AM(UTC)
Where are the date codes on the side of the blocks.I know my numbers are right because I have the original owners service books. I still do plumbing work for the original owner. Thanks Bazza.
#7 Posted : Friday, 16 May 2008 6:20:55 AM(UTC)
On one side of the block near the freeze plugs on the McKinnon blocks. Big wide number across a few inches from memory. It's on the rear near the casting number on Tonnawanda 327 and 350 blocks.
#8 Posted : Friday, 16 May 2008 6:20:55 AM(UTC)
On one side of the block near the freeze plugs on the McKinnon blocks. Big wide number across a few inches from memory. Its on the rear near the casting number on Tonnawanda 327 and 350 blocks.
I
This page was generated in 0.065 seconds.
