pdtphil Offline
#1 Posted : Friday, 30 May 2008 7:34:44 PM(UTC)
pdtphil
Hi all, I have tried to canvass this before but I wish to try again.
I have a HJ Van 308 4 speed with a '11qt' rebuilt motor with mild cam.
The problem; The alt guage, when cold, goes up to the red area then fluctuates for a few minutes. It makes the radio cut out intermittantly and at night the headlights go through a bright glow when in the red and then drops a bit when the alt guage comes into normal range. It only does this for a couples of minutes till warm, then stays at the normal range from then on. The Alt is a bosch with what appears to be an inbuilt Reg. I say this because there is no separate regulator.
I have a Lucas alt as a spare and looks like it doesn't have the brown bakalite attachment like the bosch. Can I put this one on to check if the bosch is faulty? Or get a new alt?
Any thoughts
"If in doubt, Power out"
jabba Offline
#2 Posted : Friday, 30 May 2008 8:07:50 PM(UTC)
jabba
Find a reasonable auto electrical place. They should have a test rig where they can spin up the alternator and check the output voltage at various rpm. That should tell you if the alternator / regulator are dodgy or not.
If regulator is dodgy, you may
pdtphil Offline
#3 Posted : Friday, 30 May 2008 9:27:25 PM(UTC)
pdtphil
Thanx Jabba, I would like to see if there is a simple solution prior to going for diagnosis with an expert. Is there a test I can do myself, I have various test gauges, if that helps, but don't know exactly I'm testing for.
When I bought the van about
pdtphil Offline
#4 Posted : Friday, 30 May 2008 9:27:25 PM(UTC)
pdtphil
Thanx Jabba, I would like to see if there is a simple solution prior to going for diagnosis with an expert. Is there a test I can do myself, I have various test gauges, if that helps, but dont know exactly Im testing for.
When I bought the van about 6
#5 Posted : Saturday, 31 May 2008 1:39:38 AM(UTC)
i had a similar problem on my hq 202 auto the charge light wouldnt go out battery charged up ok lights stayed bright checked the fuse connections and cleaned the dust out and now the light goes out when running atb
#6 Posted : Saturday, 31 May 2008 2:12:09 AM(UTC)
Measure the battery voltage when the engine is off. Should be somewhere between 12 and 13.8V. Measure it again with everything normalised and engine running. Battery volatge should be about 14.2V or thereabouts. This is a good starting point for checking
#7 Posted : Saturday, 31 May 2008 2:33:00 AM(UTC)
If your Bosch alternator has the built in regulator it will be a black plastic box held on to the back of the alternator with 2 screws.
Those regulators can give trouble and cost about $40 for a new one which is cheaper than replacing an otherwise
#8 Posted : Saturday, 31 May 2008 3:58:27 AM(UTC)
Thanx for the input guys, The red light in the alt guage does come on as normal. Ill try the testing meters first, there is a strap from the negative of battery to the front apron but not to engine, so ill also try that.
Ill get back if further proble
#9 Posted : Saturday, 31 May 2008 3:58:27 AM(UTC)
Thanx for the input guys, The red light in the alt guage does come on as normal. I'll try the testing meters first, there is a strap from the negative of battery to the front apron but not to engine, so i'll also try that.
I'll get back if further pro
#10 Posted : Saturday, 31 May 2008 6:57:35 AM(UTC)
There has to be a strap to the engine or the starter wouldn't crank.
#11 Posted : Saturday, 31 May 2008 6:57:35 AM(UTC)
There has to be a strap to the engine or the starter wouldnt crank.
#12 Posted : Monday, 2 June 2008 12:31:45 AM(UTC)
My mistake, there is a strap from the bat to the front of the bat. Im exploring any other possibilities for the fluctuation. could it exist on the guages or anything else.
#13 Posted : Monday, 2 June 2008 12:31:45 AM(UTC)
My mistake, there is a strap from the bat to the front of the bat. I'm exploring any other possibilities for the fluctuation. could it exist on the guages or anything else.
81837 Offline
#14 Posted : Monday, 2 June 2008 1:25:37 AM(UTC)
81837
This does not sound like an altenator problem, the battery starts the engine so must be OK, if the alternator was not charging the radio and lights would work normally until the battery went flat. It sounds like a connecton, maybe the positive wire from t
pdtphil Offline
#15 Posted : Tuesday, 3 June 2008 3:22:26 PM(UTC)
pdtphil
Thanx 81837, the GTS dash was in it when I bought it about 7 years ago. There were issues which turned out to be earth straps from body to chassis etc, but that was fixed, I've got plenty of them on now. Can the solenoid on starter be going?
Cheers P
pdtphil Offline
#16 Posted : Tuesday, 3 June 2008 3:22:26 PM(UTC)
pdtphil
Thanx 81837, the GTS dash was in it when I bought it about 7 years ago. There were issues which turned out to be earth straps from body to chassis etc, but that was fixed, Ive got plenty of them on now. Can the solenoid on starter be going?
Cheers Ph
This page was generated in 0.083 seconds.
