Fred Offline
#1 Posted : Friday, 6 June 2008 1:05:59 PM(UTC)
Fred
Some friends of ours had a dismantled 253 that they were going to rebuild before the floods, now when they unpacked after the flood most of the parts that where in water filled tins were dumped.
The parts they do have are the block, 2 heads, 1 cam, 1 crank shaft which were all rebuild 6 months ago so my question
is are all the other parts available as a kit purchase or would buying
a second hand motor and using the internal parts be suitable, if a kit can be purchased where would one go.
#2 Posted : Saturday, 7 June 2008 2:23:34 AM(UTC)
what ????
basketcasebear Offline
#3 Posted : Saturday, 7 June 2008 3:59:48 AM(UTC)
basketcasebear
gee fred,
i would ring around, check prices on parts etc,
but if the block is good and the heads crank etc, then you got most of it already,
a second hand motor might be clagged??
just my thoughts,
by the by,
if a 253 is the same as a 308, can you s
DOH!!!
FastEHHolden Offline
#4 Posted : Saturday, 7 June 2008 6:15:33 AM(UTC)
FastEHHolden
basketcasebear- There are stroker kits for 253 to 312....but I think what you are asking is can you put a 308 crank in a 253 and get it to 308...the answer is no..as its the piston size that is the difference between the two.
Fred- I have a std bore bl
#5 Posted : Saturday, 7 June 2008 6:56:00 AM(UTC)
basketcasebear
hey thanks fasteh,
i was actually askin about 253>308 more about price of,?
eg lots 253 around, not as many 308,s
what i was planning ahead too, was later model heads on my 308, or later model heads on another 308block?
if i do my 308, not sure on
DOH!!!
boom Offline
#6 Posted : Saturday, 7 June 2008 11:36:15 AM(UTC)
boom
253s wont work with the later VN heads, the valves hit the top of the bore. this is also the case with L34 sized valves (they are exactly the same)
The only way to do it is to notch the top of the bore.
In cubes we trust
This page was generated in 0.111 seconds.
