what would a hk 327 shell be worth thats had everything taken of it, including tags,sag hump tank hump, but other wise good nick? everthing was put on another shell...
Thanks: 1 times Was thanked: 558 time(s) in 533 post(s)
Bugger all, except for body parts if they are not rusty eg roof, quarters etc. I imagine its pretty stuffed though if everything was put onto another shell. I also assume the firewall was transplanted too as the chassis number on the firewall has to match Edited by user Wednesday, 11 June 2008 3:18:20 AM(UTC)
| Reason: Not specified |
Bugger all, except for body parts if they are not rusty eg roof, quarters etc. I imagine it's pretty stuffed though if everything was put onto another shell. I also assume the firewall was transplanted too as the chassis number on the firewall has to matc Edited by user Wednesday, 11 June 2008 3:18:20 AM(UTC)
worth bugger all? but you still want them. all HKs should be crushed, with there owners in them also
Idiot - grow some balls. Bugger all as a "Monaro". No tags. Floor humps cut out. Still worth good money for body sections. Probably worth up to $6k if it is not rusty, but why else would it have humps and tags removed?
_________________________________ |
why would you go and do that if the shell is in good nick just curious
as Byron said 2 rear quarters plus roof if all usable up to $6k, then any other bits add more I need right rear quarter might be able to help you Byron with right wheel arch on quarter my silly son inlaw cut off, was damaged at "B" pillar, will check
Joined: 4/12/2005(UTC) Posts: 1,062  ![Australia Australia]() Location: western victoria
I could have done with a roof/pillar section just above the rear R/H window but couldn't find anything for over two years and now i'm done, something shows up :-( If someone cuts this body up and it's before i paint, i may be interested in buying the b |
Fossil fuels are YUMMY ! |
I could have done with a roof/pillar section just above the rear R/H window but couldnt find anything for over two years and now im done, something shows up :-( If someone cuts this body up and its before i paint, i may be interested in buying the bit |
