#1 Posted : Wednesday, 11 June 2008 8:47:59 PM(UTC)
Hi guys, Need some help finding a legible vacuum schematic for the air con controls in a XC / ZH.
If someone has a factory manual or a a/c vaccuum schematic can you please look up where black vaccuum hose that connects to the "Vac in" of the "water valve vaccuum switch" tees into.
It looks as though it might tee into the blue hose from the main a/c control switch. I do have two factory manuals, one original, one reprint, but both have this same part of the vacuum shematic unreadable :-(
schematic is in section 16 page 15. hopefully someone has a legible manual out there. thanks heaps, Nathan
#2 Posted : Thursday, 12 June 2008 6:24:46 AM(UTC)
It does appear that it is bridged over the white hose and tees into the blue line, but my manual is obviously as bad as yours.
I suspect all of the manuals must be the same? Good luck anyway.
#3 Posted : Friday, 13 June 2008 5:19:34 AM(UTC)
Thanks for your help, it does indeed tee into the blue hose. Apparently every factory manual (according to the printer) has the same crappy unreadable diagram. Local air con guru helped out as well, Nathan
