I recently had the battery changed in the key for my Astra but now the central locking doesn't work with that key. I have been told there is some way to fix it (like holding a button down when turning the key or something), anyone know how to do it?
Joined: 2/03/2005(UTC) Posts: 491 ![Australia Australia]() Thanks: 3 times Was thanked: 8 time(s) in 8 post(s)
Beth, switch on ignition, leave key in the switch, briefly press one of the buttons, you should hear the locks open and close, then remove key and all should be ok. AL.
Thanks a lot for that, the problem is now fixed!
