sandman-utes Offline
#1 Posted : Friday, 8 February 2008 3:47:25 AM(UTC)
sandman-utes
Hello all, i have been told that the DFI module needs replacing on
my vx with the crank angle sensor. I had it put on the computer, and a
few codes come up. It took a fair bit of cranking to start the
other night. codes that come up were;
0046 no referencepulses while cranking
0047 18x reference signal missing
0049 cam/crank sensor signal intermittent.
And of course the good old ABS code DTC24 actual torque circuit
fault &Airbag code 163 sdm internal fault
I was told that when replacing the crank angle sensor the DFI module
needs replacing as well. Any comments on that? Had a second quote
on the parts and will save over $165 from another holden dealer,
still it comes to $705, Might be time to trade in.... B4 it all
turns to siht.
Any help is greatly appreciated Anton
no shame in Growing old disgracefully!
"Experience is a hard teacher because she gives the test first, and the lesson afterwards"
This page was generated in 0.017 seconds.
