#1 Posted : Wednesday, 6 August 2008 9:21:22 PM(UTC)
Hi guys I am reassembling a HT heater motor. Each end of the shaft has a spherical bearing type arrangement on each end the motor body. If you know what I mean. It goes cover, felt washer, bearing thingy, spring retainer, retainer (pressed into cover). Anyways what I wanted to know is what lubricant to use in this area. Should I soak the felt washer in normal engine oil, gear lube or a dielectric grease/oil or? Also should I put some graphite or something where the brushes run? Any other tips please?
Thanks in advance, Ricky
#2 Posted : Monday, 11 August 2008 9:21:54 PM(UTC)
bmup?
any sparkies here?
